cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
How to invert a byte ?
Resolvido!
Ir para a solução
What i want to do sounds simply so far but i can't find out a solution which can be that simple...
I have an array of byte for example : 1101 1010 and I'd like to invert it like this : 0101 1011
I did not find the VI to do this. I think it's not a Big/Little -endian issue. I have an idea about converting the byte in string and use the string revert VI. Then get back to byte but it's not optimised.
Have you got ideas ?
Thanks for the help !
Message Edité par xela75 le 09-01-2009 06:56 AM
Message Edité par xela75 le 09-01-2009 06:57 AM
Mensagem 1 de 7
8.884Exibições
It looks like you have an array of bits, however the easiest is to get a numeric representation of the byte (an U8) and use the boolean invert function.
Ton
Message Edited by TonP on 01-09-2009 02:01 PM
My LabVIEW Ideas
Mensagem 2 de 7
8.878Exibições
You propably want to XOR it with a bit-mask.
Felix
Mensagem 3 de 7
8.871Exibições
Solução
Aceita pelo autor do tópico xela75
xela75,
It sounds like you want to reverse the bit order of a U8?  If so, try this.
Mensagem 4 de 7
8.853Exibições
Wayne.C,
It's weird that there is not a VI which does it...But your solution is interesting.
Mensagem 5 de 7
8.838Exibições
Your solution is a good one !
Thank everybody for the help !
Message Edité par xela75 le 09-01-2009 07:56 AM
Mensagem 6 de 7
8.830Exibições
Just for fun: (the hex constants are U64)
Mensagem 7 de 7
8.783Exibições
