How to interface windows telnet or putty or plink software with LabVIEW
Please find the attched screen screenshot of the problem that am facing here.
Problem is, am able to open the telnet session using IP address of the UNIT. But after that am not able to send commands or arguement to putty or plink.
System Exec is not accepting the standard input.
In the screenshot plink.exe started working only after sending enter to it manually... and after getting the prompt ">" if I send "SEND" command to plink.exe it replies back with data from Unit.
Here I am not able to automate this sending Enter and SEND command to get the data from Unit.
It will be grateful if anyone give me a solution.
Vijay
(13,421 Views)
Hi!
To handle Telnet sessions I'd suggest to use the Telnet VIs provided with the Internet Toolkit.
Have a look here: http://zone.ni.com/reference/en-XX/help/370014D-01/internet/telnet_vis/
Marco
(13,409 Views)
Even I tried with with LabVIEW Telnet VI's. It doesn't helped me much.
Pls find the attachment with this.
(13,401 Views)
Hi!
Can you post a LV8.6 version of your VIs?
Thanks in advance,
Marco
(13,395 Views)
Accepted by Vijay@M
I solved this with Telnet VI's by appending \r\n for all commands that we send to Unit.
Pls find the attached final VI in LabVIEW 8.6
Vijay
(13,382 Views)
