How to integrate AI signal through FPGA
I build fpga VI in while loop to acquire AI signal and I need to intgrate this signal twice to obtain the velocity and displacement. I found integrator in Simulation and design but I can not put the integrator in FPGA while loop
(3,457 Views)
Is it a regular while loop or timed loop?  Can the integrated be used out side of the loop?  For example, acquire your analog signal in one loop and pass it to a slower loop for integration.
(3,450 Views)
Thanks 4 reply
It is normal while loop.
The problem is that the integrator exist is simulation and design module
Is it possible to put another loop containg the integrator
(3,446 Views)
From a VI under an FPGA target, look at FPGA Math & Analysis >> Control >> Discrete Linear Systems >> Discrete Normalized Integrator
Jim
(3,429 Views)
Thanks a lot
(3,413 Views)
