How to install Exaprom PDF 1.0?
Hi, I'm having problems to see the "Free PDF Report with ItextSharp" from Exaprom PDF. When I put it in the folder user.lib, the links not appears! Please, see the images below! Thks!
Message 1 of 9
(6,626 Views)
You didn't unzip the archive containing the stuff you need. With Windows a "compressed folder" is really just a zip archive and LV can't see inside zip archives - which come to think of it would be a really neat addition...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(6,619 Views)
No...I unzipped all...I think that you see only the zipped folder! There's a folder zipped and unzipped!!!
Thks!
Message 3 of 9
(6,609 Views)
Accepted by topic author Neat
Rename the directory "Exaprom PDF 1.0" with the name ""Exaprom PDF"
Message 4 of 9
(6,576 Views)
Great....everything is working!!!
Thanks!!!
Message 5 of 9
(6,571 Views)
A question about the compatibility between the old Exaprom PDF and the newer Exaprom PDF 1.0. So far I had an application in LV8.5 using the older Exaprom PDF, but for the new version of this application in LV2011 I wanted to use the new Exaprom PDF 1.0 which is for LV8.6 and higher. When replacing the Exaprom with the new one, the Exaprom vis have to be relinked and somevis and type defs are not found. Is there any help or documentation for this switch of Exaprom version or am I doing something wrong? Thanks for any help!
Message 6 of 9
(6,386 Views)
Yes, If you switch to Exaprom 1.0, some VIs and typedef will be missing.
Unfortunately, there is no such documentation for this, and I don't have those two versions on my computer (I work with a newer version).
Message 7 of 9
(6,379 Views)
Bonjour Jean-Marc, you say you work with a newer version of Exaprom. Is it a public version or your personal? The Exaprom 1.0 is the newest I could find. Do I understand right, are you the developer of it? I really like the tool!
Message 8 of 9
(6,360 Views)
Yes, I work with a newer version, but this version is less “users friendly," and not compatible with the other versions (too many modifications).   This version includes Unicode text (left to right writing), more sophisticated tables (horizontal merging, but not the vertical merging), TOC, etc.  I implemented Unicode text everywhere (footer, header, table, TOC, etc.,), but I didn’t have time for extensive testing. Furthermore, I don’t have the time to upgrade the documentation.
In short, I intended to make this version public but without testing and proper documentation (in english this time), the tool will be probably a nightmare for other user than me...
Message 9 of 9
(6,346 Views)
