How to insert an array of number into access database?
How can I insert an array of numbers(double) into an access database and later read them back to an array I labview. I don't have the Database Connectivity toolset. I would prefer using the LABSQL or other free solution. Any idea on how to solve this. I have tried LABSQL and SQL commands, but when I do that I have to convert the number to a string and then make a SQL-command string. Is there a way where I don't have to convert the number into a string?
(2,632 Views)
I am not familiar with LABSQL and we do not do any support on that particular product. However I still want to give you some information on how to proceed. You can either store the array to binary format and by doing this you can save an entire array to one single element of the database. The other alternative is of course to save one-to-one in other words one element of the array in one element in the database.
More info can be found here:
http://digital.ni.com/public.nsf/websearch/3FE68BBDA95E845986256DB4006A22C0?OpenDocument
Have you checked MSDN for information regarding this? You might be able to find useful SQL code there to use.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,596 Views)
