em 06-20-2011 10:26 AM
Solucionado! Ir para Solução.
em 06-20-2011 10:33 AM
em 06-21-2011 03:29 AM
Hello londonew
I sorry but all images you attach into a graph always appear in the top left corner. The only way to plot the image in a different point is to create an image with a transparent frame or similar. Be careful because depending on what plot option you select it has a different behavior (check the attached example)
em 06-21-2011 03:29 PM
em 06-21-2011 03:31 PM
What type of picture are you trying to add? A bitmap image (jpg,png..), or something created with the drawing VIs? There can be some relatively simple workarounds depending on the picture type.
em 06-21-2011 03:59 PM
em 06-21-2011 04:12 PM
This should work:
em 06-22-2011 04:55 AM
06-22-2011 07:50 AM - editado 06-22-2011 07:52 AM
The structure (InPlace Element) does not exist in LabVIEW 8.2. It can be replaced by an unbundle followed by a bundle. I have attached the equivalent LV 8.2 VI.
P.S. Use of VIs in vi.lib which are not on the palette (two in this example) can lead to programs which get broken in later versions of LabVIEW when the VIs change. Only VIs on the palettes are guaranteed to be forward compatible.
em 06-22-2011 07:54 AM
