How to insert a graph in MSWord using ActiveX
How to create the graph in MS WORD using LabVIEW ActiveX
(3,054 Views)
Hello ssdsdc,
You can also use the Report Generation Toolkit to create your reports in Word.
Have you tried this?
This will save you quite some time.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,998 Views)
Currently I am using report Generation toolkit, If I want to use multiple chart in a single Excel Chart(that is XLColumnCluster Chart and also to add trendline in a same chart) is it possible to do with report generation toolkit
Regards
Ajay
(2,993 Views)
Hello Ajay,
Can you post the code you're currently using and the template your using in th Report Generation Toolkit (if it's not one fo the default ones)?
Kind Regards,
(2,983 Views)
