How to increase the width of the Y scale area on a mixed signal graph?
Hi!  This is my first time using a mixed signal graph, and I have been unsuccessful in widening the y scale area in order to view the values.  Also, I've noticed in other postings the ability to display the units.  How is this accomplished?
Thanks!
Message 1 of 10
(3,854 Views)
yoi can grab the Y-axis with your mouse in the middle and drag it to the right.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 10
(3,850 Views)
Thanks, perhaps I'm doing something wrong, but when I try to grab just the Y-axis, the entire mixed graph is selected and I resize the entire graph.  Is there something special to do here, or a specific location I need to click.  I thought this should be the case, but have been unsuccessful with the mixed signal graph.  True, one can do this with a simple single waveform graph.
Message 3 of 10
(3,845 Views)
don't select the graph. hover over the graph untill you see handles.  Drag the one indicated to the right.  I never use mixed graphs so I dont know if it works there Smiley Indifferent
Kind regards,
- Bjorn -
Message 4 of 10
(3,842 Views)
I feel like this should be so simple!  I agree that is true with an XY graph or waveform graph and can resize them, but could you try a mixed signal graph with two stacked graphs to see if you get the handles?  My version (?) does not allow this.
Thanks!
Message 5 of 10
(3,838 Views)
Doesnt work for me either.  I havent got a clue how.  For sure somebody else does.  Sorry
Kind regards,
- Bjorn -
Message 6 of 10
(3,836 Views)
Have you tried setting the dimensions with the PlotArea property node?
Product Support Engineer
Message 7 of 10
(3,821 Views)
I believe so.  I've tried to set the PlotArea, Size, Width and that adjusts the entire plot but the width of the y-axis values remains the same unreadable size.  I have found a Y Scale, Bounds, Area Width property, but this comes up as read only and does not allow me to attach a constant to it (the option is grayed out).
Any other ideas?
Thanks!
Message 8 of 10
(3,818 Views)
Try checking out this help file from LabVIEW 8.6.
http://zone.ni.com/devzone/cda/tut/p/id/3686
Hope that helps!
Sarah Yost
Senior Product Marketing Manager
Message 9 of 10
(3,808 Views)
Hello Eric, open your graph in "Customize"-window (Edit / Customize control) and switch to customize mode. Then you will be able to change the size of the plot and adjusting the scale positions.
Cheers,
Cerati
Message 10 of 10
(3,799 Views)
