How to include hardware configuration in the installer?
I have a VI developed with LabVIEW 2009 V9.0f2 using a USB-6009 and two of its analog inputs.  The VI uses the DAQ Assistant to configure the USB-6009.  I include the DAQmx Core Runtime 9.0.2 with the LabVIEW Runtime Engine 2009 in the installer build.  I spent most of the past week trying to get the application to run after installation.
 If I leave out the Hardware Configuration from MAX (no configData.nce file) and run the installer on another machine the application produces an Error-200378 Custom Scale Specified Does Not Exist  when it runs (I searched the 200378 error code - no help).
If I include the Hardware Configuration from MAX to produce a configData.nce file, and select Perform the Import Silently to Merge the Import Data when the installer is built, I get this message during the install to another computer:
.\Distribution.cpp(1902): IInstallerError 11004Developer Error. Distribution contains invalid dependencies:1. Product NI Remote Provider for MAX 4.6.1 ({FBD23528-31AC-412A-9DEE-6CEA814A7430}) depends on product with upgrade code {B5171839-26E3-48D9-9FD6-AF7F39055146}, version [8.2.379.0,), language in {} which is not in the distibution.2. Product NI LabVIEW Real-Time Error Dialog ({297FA251-FF30-4F16-978C-4A65EA804EFF}) depends on product with upgrade code {B5171839-26E3-48D9-9FD6-AF7F39055146}, version [8.2.379.0,), language in {} which is not in the distibution.3. Product NI LVBrokerAux 8.2.1 ({0FB31DF8-38DF-4C9D-B313-AFAFC3FBA02B}) depends on product with upgrade code {B5171839-26E3-48D9-9FD6-AF7F39055146}, version [8.2.379.0,), language in {} which is not in the distibution.Correct the distribution and try again.
I’m not really sure that the installer even uses the configData.nce file during the build.
Another error I have seen (I have done several other builds using various installer settings)  is that the app appears to run fine except it is unable to find the USB-6009, even though the operating system picks it up and installs it in the device manager seemingly without error.
I am a novice LabVIEW user.  Any help you could give would be greatly appreciated.
Bill
(5,168 Views)
Monday morning bump.
(5,131 Views)
Hi Willygene,
Give the steps listed in KnowledgeBase 52GH9OW5: Why Do I Get Error 200378 When Running a Stand Alone Application? a shot, does this help with the 200378 error?
Do you have DAQmx installed on the other machine? Are you unbundling it with your installer? If so, what Run-Time Level are you buiding into your installer? Can you post screenshots of the errors that you are getting?
Joshua B.
(5,101 Views)
Accepted by Willygene
Hello Joshua,
I’ve got it now; I got the hint form the link you provided.  I didn’t realize that I needed to include DAQ-mx task under My Computer (right-click My Computer) in the Project Explorer in order to get the configuration file for the USB-6009 included in the application build.  The NI-DAQmx.ini file is put into the data folder of the application.
Now when I choose Include hardware from configuration from MAX from the Installer, it looks to the application data folder for the NI-DAQmx.ini configuration file.
Thanks for pointing me in the right direction.
Bill
(5,068 Views)
