How to import a spreadsheet file into a histogram
Built labview program which is excepted the read data from spreadsheet (two different rows ) .Could someone please tell me if this correctly built. Haven't included that excepted convert this data into histogram
(2,384 Views)
Hi Ripper,
Did you know that LabVIEW comes with a boatload of examples to help you learn new features? Go to Help >> Find Examples... and search for histogram, you will find a bunch of examples. I think "Running Histogram.vi" will be useful to you.
  • Since you have all your data available to you at once, do not use the pt by pt version, that is for one data point at a time.
  • Once you have your text data, you need to convert it into the appropriate numeric data type, using for instance "fract/exp string to number".
(2,355 Views)
