How to import Verilog codes into LabVIEW FPGA?
Hi Spex,
Thankyou for your valuable advice in time.I was posting for the first time so could not notice that it was an already solved thread.Well i have re-posted my question on this link http://forums.ni.com/t5/Real-Time-Measurement-and/Compilation-error-in-importing-VHDL-Wrapper-file-f.... Now looking forward to help from other engineers regarding this issue.
Cheers!
Message 11 of 17
(1,626 Views)
Hi Softmind,
I also need to import the Verilog file into Labview, but cannot open the link
http://digital.ni.com/public.nsf/allkb/7269557B205B1E1A86257640000910D3
Any help?
Message 12 of 17
(1,543 Views)
Hi @T-REX$,
It seems there is manual about how to import the verilog file into Labview. But I cannot open the link you posted, as I cannot open the link Softmind referred to.
Would you kindly send me the file of the hypelink you posted?
@T-REX$ wrote:
The best instructions that we have for integrating Verilog IP into LabVIEW FPGA can be found here: Using Verilog Modules in a Component-Level Design. My suspicion is that you didn't uncheck the "Add I/O Buffers" option in the Xilinx Specific Options setting in ISE when running XST (see page 8 of the .pdf)
Message 13 of 17
(1,542 Views)
Try this white paper instead: http://www.ni.com/tutorial/7444/en/
It discusses how to integrate external IP into LabVIEW FPGA.
Message 14 of 17
(1,519 Views)
Dear T-REX$,
The page about example is lost. Could you share it again please?
Much thanks.
Message 15 of 17
(667 Views)
Message 16 of 17
(655 Views)
Thank you very much. And I wonder if Labview FPGA only supports VHDL to be integrated and not verilog.
Message 17 of 17
(624 Views)
