How to impliment labview/modbus with a Baldor H2 AC motor controller
Looks like you are getting an echo back.  Try sending this packet in hex, "01 03 A0 30 00 01 crc".  You should get the following packet back, "01 03 04 00 XX 00 00 crc"  Where XX is 00 or 01 for stop, 02 for forward and 03 for reverse.  You should be able to manually set the drive to forward and/or reverse and see this value change when you read again.  What brand and model of 485 adapter are you using?
Steve
Message 11 of 19
(2,060 Views)
Iam getting an echo back,  when i sent the last data packet the drive returns with the same info sent.  The converter iam using is from http://www.rs485.com/pdffiles/converters/ssac44l.pdf, Since the 485 is only 2 wire from the drive i have placed jumpers for the converter.
Jarrett
Message 12 of 19
(2,058 Views)
You should have TX- and RX- tied together and to pin B on the drive then TX+ and RX+ tied together and to pin A on the drive.  Also COM to pin G on the drive.
Steve
Message 13 of 19
(2,054 Views)
The 485 is connected up correctly, something is fairly wierd here...
Jarrett
Message 14 of 19
(2,052 Views)
The only thing I can think of for you to try is your RS232 cable.  If you are using a null modem try a standard and vice/versa.
Message 15 of 19
(2,049 Views)
It was my 485 converter, only does full duplex, i switched to a bluetooth serial port now everything works,
Thanks for the help, if you have any other tips or codes to try out let me know
Jarrett
Message 16 of 19
(2,028 Views)
Just curious how you found out what register 41008 did, i can't find any documentation from register 41000 to 49999.  Also how do you read the 32 bit data coming out  from the holding registers
Jarrett
Message 17 of 19
(2,015 Views)
Modbus only reads 16 bit registers, you have to make it 32 bit or floating point inside the labview software. Try typecasting.
Message 18 of 19
(2,004 Views)
If you look at the end of the holding register table (table 10) registers 41000 - 49999 are actually the parameters.  In the back of your drive manual is a table with all the parameters.  "Unclebump" is right in that MODBUS only supports 16bit data that is why each parameter is two bytes worth of data.  The trick is the first byte received is the LO byte.  To get floating point you combine the two bytes and send through type cast with SINGLE as the 'type'.
Message 19 of 19
(1,996 Views)
