Can't Move Column Separators in Multicolumn List Box
Hi All,
I just put a Multicolumn Listbox onto the front panel. I can't move any of the column separators, regardless of what I do or try. Is this a known behaviour?
LabVIEW 8.2 english, Windows XP German
Best regards
Matthias
(3,307 Views)
Do you mean varying the width of each column????
This you can adjust using the 'Position/size/select' Tool, ( pointer tool)
Dev
(3,306 Views)
thanks for your reply. To be more clear, I have been using multicolumn listboxes for some time in LabVIEW 7, where the resizing as you describe it worked very well. Now, under LV 8.2, it does not work any more.
Regards
Matthias
(3,304 Views)
Hi again,
I tried it now at a different machine, where we have the Full license - there I can move the column separators...
On my machine, where I have a Professional version, I can't.
Maybe I am to full to be professional? ;-(
Update: See http://forums.ni.com/ni/board/message?board.id=170&message.id=177856 - I do use a SCC (Serena ChangeMan Version 8.1). This is obviously linked to it. We don't have it installed on the machine with the full license!
Regards
Matthias
Message Edited by matthias.richwin on 12-19-2006 11:29 AM
(3,303 Views)
This is sort of a bug (not fully reproducible), but in run mode (ctrl-m) I can always move the headers (if I allow user to do so)
Ton
My LabVIEW Ideas
(3,286 Views)
yes, this works as a workaround...
Thanks & Best regards
Matthias
(3,282 Views)
