How to implement two button dialog box
I have a program to ramp voltage current, and in the display were you enter the voltage current I made it so that if you enter a value greater then 3 ( using a comparison vi > 3 connected to a case box with a text message
that pops up when the value is true) it asks you if you are sure, but i want to make it so that it doesn't ramp the volatage until you click okay How would I do taht
(3,413 Views)
Hi Eugene,
I am not sure I understood your question fully but there is a two button dialog in LabVIEW already. You can find it under Time & Dialog. This function outputs the outcome of the users answer and all you have to do is check for a true on this output before you ramp your voltage/current. Hope this helps./Mikael
(3,413 Views)
Eugene,
Try modifying the attached to fit your need.
Run without the Continuous mode, as I did not set in a break option.
Good Luck, Doug
(3,413 Views)
