‎07-02-2018 05:38 AM - edited ‎07-02-2018 05:46 AM
Hi James,
Can we directly view the temporary signal from the electrodes when we connect the output of the amplified signal into the Analog Input of myRIO? We're using a waveform chart to view the signal
Yes, you can view your signal directly using this chart…
Right now your samplerate is even less with just 1Hz due to the 1000ms wait in the loop!
‎07-02-2018 05:44 AM
So we just need to increase the sample rate? There's nothing wrong with our VI implementation except the sample rate?
‎07-02-2018 05:49 AM
Hi James,
You can increase the sample rate by reducing the wait time.
BUT: then you are limited by the execution speed of this ReadAI function.
The better option is to employ hardware-timing (if possible) and read more than one sample per Read call!
Again: I guess there are example VIs explaining such stuff for your myRIO…
‎07-02-2018 11:00 PM
Thank you! Also, do we need to convert the raw acquired data from myrio into voltage?
‎07-03-2018 12:31 AM
‎07-03-2018 01:45 AM
We can now get the values from the analog input. But we cannot get any negative voltage
‎07-03-2018 01:54 AM
Hi James,
which analog input did you use?
There are different types of AI - and all support a different input range!
‎07-03-2018 02:30 AM
We used the MSP already and we were able to acquire negative values. Any idea how to convert this waveform into a signal?
‎07-03-2018 03:06 AM
Hi James,
Any idea what's the difference between a waveform and a "signal"? (I don't know the difference.)
Which kind of "signal" do you need? Why don't you stick with your waveform?
‎07-03-2018 03:38 AM
When we use a chart it gives us an error. We need this waveform graph because we will use WA detrend VI
