03-23-2011 06:24 AM
Hi
Is there any way to identify the CAN devices to the PC via USB port, I am able to see the connected CAN hardware name in the device manager list. Same I would like to read using LabVIEW.
Regars
Visuman
Solved! Go to Solution.
03-23-2011 06:57 AM
Try the following VI.
In LV version 2010
03-23-2011 07:22 AM
Thanks for the reply can you send the same in 2009 version I dont have LabVIEW 2010.
Regards
Bharath
03-23-2011 07:36 AM
Here we go LV86
03-24-2011 12:59 AM
The VI is searching for some support files, kindly attach the support files also in 8.5 version.
03-24-2011 06:20 AM
You will need the
03-28-2011 01:06 AM
Hi
Thanks for the reply, code is listing only the NI device. But I would like to see the connected third party devices also which I am seeing in the device manager.
Regards
Visuman
03-28-2011 07:10 AM
Use the vi in the zip file.
And the "Devcon.exe" will show you the device list.
With this list you may sort out the devices bei searching the string.
03-29-2011 03:38 AM
Thanks its working.
Regards
Visuman
