How to identify "front panel coordinates" of a marker on a 2d picture( google static Api map) in labview ?
Hello
I am working on a project which requires me to obtain the front panel coordinate of a marker placed on a 2d picture of a map. The map is being obtained by sending http request to google. I am using static google maps to obtain the map. Below is a picture of front panel with the marker pointing at a location on the map.The position of the marker keeps on varying around the picture as i change the input location. Hence i need a way to record the changes in position of the marker on the map.
Thank you
Message 1 of 1
(2,699 Views)
