How can i change the background of labview front panel
As title stated, i want to change the background of my front panel. How do i start doing it? Thanks
Another qns how do i put my description inside my combo box. Thanks
Message 1 of 11
(6,689 Views)
Right click on a scrollbar and pick properties.  You can change the background of the pane.
I don't know what a "qns" is.
What do you mean by put your "description inside a combo box"?
Message 2 of 11
(6,677 Views)
sorry qns mean question. Because now my combo box during statup is blank. how can i put "select SMS" in the blank.
Message 3 of 11
(6,674 Views)
Check if it helps you!!!
uday
Message 4 of 11
(6,640 Views)
To change the background color you would shift-right-click (to get the tools palette), pick the paint brush, and click on the background (same as you would color any other object.
To make a specific control value the default, you enter the value first, then right-click the control...data operation...make current value default. Save the VI.
Message 5 of 11
(6,631 Views)
But after i select my data, it wont jump back to my default value.
Message 6 of 11
(6,520 Views)
@gabriellimhj wrote:
But after I select my data, it wont jump back to my default value.
What does that mean?  What are you trying to do and what are you expecting to happen?
Message 7 of 11
(6,513 Views)
I mean after i select my SMS content and number and i press send. After sending it will return to my default value.
Message 8 of 11
(6,488 Views)
Create property node for the same control and at the end of your case, write default(whatever value) you want.
uday
Message 9 of 11
(6,478 Views)
There are plenty of properties. You probably mean a value property.
It is typically more efficient to use a local variable instead of a value property.
Message 10 of 11
(6,445 Views)
