How to hidden Labview startup window when Teststand Start Loading
I have Teststand development enviroment and Labview development enviroment installed on my computer,my teststand application use Labview adapter. Question is each time when I start running Teststand application,Labview start-up window will auto pop-up, I want to customize this behavior to let Labview just show in the taskbar.
(3,670 Views)
When you start LabVIEW, the Getting Started window appears. Complete the following steps to launch LabVIEW without the Getting Started window.
  1. Select Tools»Options to display the Options dialog box.
  2. Select Environment from the Category list.
  3. Place a checkmark in the Skip Getting Started window on launch checkbox.
  4. Click the OK button.
Ref: https://www.ni.com/docs/en-US/bundle/labview/page/disabling-the-getting-started-window.html
uday
(3,622 Views)
Accepted by topic author DanielDu
When distributing applications, everything should run in the runtime engine (RTE). It should not require developement environments (Dev Env) to be installed on the machine at all.
That being said, i recommend you to configure the TS LV adapter to execute VIs in the RTE. That will automatically get rid of the launch dialog as that one is part of the LV Dev Env.
Norbert
Norbert
Expert: Geometry
(3,617 Views)
Hi Norbet,
   Got it,thanks for your reply.
(3,608 Views)
