How to give a delay values for an array?
Accepted by NAGINENI
@NAGINENI wrote:
Thank you for your valuable inputs.
00,01,02,03,04,05,06,07
08, ..
16, ...
24,25,26,27,28,29,30,31
What result are you expecting?
Suppose if I delayed by 4 values, I am expecting
00,00,00,00,00,01,02,03
04,.
12,..
20,21,22,23,24,25,26,27.
But that's exactly what my code is doing. No need for loops or feedback nodes:
Message 21 of 23
(703 Views)
Also, if you really want to use the feedback node (why???), here's how to do it without reshaping to 1D:
Message 22 of 23
(697 Views)
Note that it is sufficient to initialize with a scalar. Same difference.
(You only need an array if the elements should differ. If the array is too short, the last valid element will be reused for the correct delay length)
Message 23 of 23
(691 Views)
