How to get waveforms directly through VISA
Because you aren't using the println string I gave you.  You are throwing in extra characters.
If you want those extra characters, then make your format string match.
Your format string should become V:%fV I:%fA based on your last screenshot.
Message 31 of 51
(1,577 Views)
I changed it still doesnot work.
Message 32 of 51
(1,575 Views)
Your previous post showed the Arduino sending out a different message first.  That would cause this error here.
Message 33 of 51
(1,565 Views)
https://www.youtube.com/watch?v=u8OEFWPCD4w&feature=youtu.be
Please help me regarding it. I send you the video in the link. Actually, video pixels is not so good. I just show you how data is coming on the COM port and what happen when i execute it on labview.
Message 34 of 51
(1,558 Views)
When I use the string that shows in the video, it works for me.
If it doesn't work for you, put a string indicator on your VI that shows the data from the VISA Read.  Run your code.  Right click on the indicator and pick Make Default.  Save the VI.  Attach.
Message 35 of 51
(1,552 Views)
Thanks for your advice. Today when i get new startup in morning. It works only once showing the graph then again same error come. When i close my complete Labview and start again it works. Which Labview version you are using. ??? I think it has some problem with my Labview 2018 64-bits. Because it works once only when i get a new start up otherwise it doesnot work. What should be the reason ?
Thanks Ravan i m near to my results if this problem has solved.
It works but no all the time. One time works then gone.
Waiting for solution.
Message 36 of 51
(1,535 Views)
Are you getting other characters in the string?  Look at the values that are coming in from the VISA Read on a String indicator and take note of what they are when it doesn't work.
Attach the latest version of your code and do it like I said in my last message where you save the values as default!
Message 37 of 51
(1,526 Views)
How ever at COM showing like this.
Message 38 of 51
(1,520 Views)
And just how do you expect the 10 characters to have a format %fV%fA?(even your terminal output shows at least 12 characters per line depending on the EOL)  And that's not what you are showing in the read buffer display- what I see in the read buffer indicator is some strange nonprintable charaters Your serial settings are still not correct!
"Should be" isn't "Is" -Jay
Message 39 of 51
(1,518 Views)
1. You are not telling the VISA Read to read enough characters.  Set that number to be a lot more than any message you could possibly receive.  I like to use 50.
2. JÞB has a good eye spotting that the read buffer looks like junk.  This points to an incorrect baud rate or some other serial port setting (parity, number of data bits, number of stop bits, etc).
3. No need for the wait in your loop.  You want to read as quick as the data comes in.
Message 40 of 51
(1,509 Views)
