How to get the value that was clicked on in a string array indicator?
I want to open a tdms file out of a folder that contains TDMS files. I have the list of files in a string array indicator. I want to click (or double click) on the indicator and have that file load. I can do everything here except get the value of the cell that was clicked on.
I was expecting "Index" to be the index of the cell that was clicked but apparently not. It always stays at zero regardless of what is clicked. When I click my timestamp test does update so I know the event loop is executing.
How to get the value of the cell clicked in a string array indicator?
(1,274 Views)
Hi flycast,
in "classic" LabVIEW I would use a listbox instead to show the filenames to the user.
It is very easy to get the active item of a listbox as it is its value…
(1,269 Views)
That seems to be the ticket!
Value gives an array of indices depending upon if single or multiple selection mode is enabled. If single then the array only has one value.
(1,252 Views)
So one more follow up question. How to detect a change in focus from one element to another using the arrow keys?
To reproduce:
 1) Click in the listbox
 2) Use the arrow key up or down to move to a different row.
(1,219 Views)
I don't have NXG but on classic, there is a property for Listboxes called Focus Row which seems to be exactly what you want.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(1,213 Views)
To reproduce:
Once a listbox item is selected, the arrow keys will move the selected entry, thus changing the value of the listbox AND triggering a "value changed" event. No need for properties. (Classic LabVIEW. Have not tried in NXG)
(1,199 Views)
