How to get the string output from ring without using property node????????
You can not. Why don't you use the property node?
(3,354 Views)
If the strings are static and you don't allow undefined values, you can index into an "array of strings" diagram constant. In the attached example (LabVIEW 8.0), we use the property node once at the start of the program and later simply index into it.
What is you reason not to use a property node? There is nothing wrong with using it. 🙂
Message Edited by altenbach on 03-27-2008 12:04 AM
(3,345 Views)
hi, not sure if attached consider one of the ways?
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,339 Views)
Thanks ....
(3,333 Views)
Hi Karthikeyan,
If you still want not to use Prop Node for getting the String of the Ring, then you can think of using the Combo instead of the Ring. Smiley Happy
A Combo's datatype is a string, so also its output. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,320 Views)
