How to get the mounted drives with full names?
How do I get the names besides C:, D:, ? In my application, I plug in a USB drive, a new drive will be mounted. I tried getLatestDrive.vi in Labview but had problems on some PCs. When my DUT is a virgin board, Labview finds the latest drive correctly. But when the DUT is a non-virgin board, Labview finds a local hard disk E:\ drive which is wrong. Again, the problem was found only on some of the PCs not all the PCs we've tested on. Since the DUT's drive name (besides the letter E: or I:, etc.) is known to me. So I want to find a function which lists the full names of the drives to locate my DUT drive without mistakes.
Thanks very much!
Spring
(5,685 Views)
I'd suggest this function to get drive name.
https://msdn.microsoft.com/en-us/library/windows/desktop/aa364996(v=vs.85).aspx
Also using the command line you can get it with something like this.
wmic logicaldisk get volumename
(5,658 Views)
Hello Hooovahh,
Thanks very much! I tried wmic logicaldisk get volumename with the systemexec.vi and it returned the volume name I was looking for. Now, how do I get the disk info as well (such as E:\ or I:\, etc.)? That command line only returned the volume name.
spring
(5,634 Views)
Accepted by 2014spring
wmic logicaldisk get name
You can read up on the help wmic is pretty useful, try
wmic logicaldisk get /?
or
wmic logicaldisk /?
or
wmic /?
(5,607 Views)
Thanks Hooovahh!
I've already found a solution:
http://forums.ni.com/t5/LabVIEW/Listing-mounted-drives/m-p/3179913#M919779
Spring
(5,549 Views)
Hello Hooovahh,
I found that ListFolder.vi only worked on some of the machines. On the other PCs where my application was deployed, it didn't work. So I replaced that Labview vi with a system Exc.vi calling for this DOS command "Cmd /C wmic logicaldisk get DeviceID" and came up with a solution! It worked on the machines where ListFolder.vi didn't work! So, I wanted to thank you very much for your valuable advices on this wmic thing! 🙂
Spring
(5,445 Views)
