How to get the hortizontal reference line on waveform chart
Hello NI community,
Currently, I am working on a Gaussmeter to get the magnetic flux intensity data. I was getting the data and program running successfully. Now I am to make a reference horizontal lines on waveform chart at exactly at -12.5mT and at 12.5mT. I was trying to keep markers in chart but nothing is working. Did not find any useful solutions for my problem Could you please suggest how do I get horizontal line in wave form chart. Looking forward to hear from you soon.
Thanks & Regards
Vijay
(2,715 Views)
Make the Waveform Chart multiplot, bundling your constant reference values together with the measured mT.
Paolo
(2,693 Views)
Hi
Thank you so much for your reply. I don’t need to plot multiple data in a waveform chart. I was getting data from the Gaussmeter in the form of a sinusoidal wave, just I need to create two horizontal lines for my reference in the waveform chart. I would like to create to horizontal line exactly at -12.5mT(milliTesla) and at 12.5mT(milliTesla). For your reference, I am attaching a picture of the desired chart. Could you please suggest me.
I have one more doubt in case if I use the multiplot waveform chart how do I need to connect to my program for getting the fixed horizontal line exactly at -12.5mT and at 12.5mT. I am attaching the program picture could you please check it
Vijay
(2,678 Views)
Accepted by vijay0507
What I suggested is AFAIK the easiest way. You need to drop a Bundle node (Cluster palette), drag to get three inputs, then wire -12.5, 12.5 and the measured value (what gets out from the multiplication by 1000 in your vi). Then wire the output cluster to Chart.
Not clear if you want to plot with a different colour between limits.
Paolo
(2,673 Views)
