How to get rid of scroll bars in sub panels when displaying a VI which is part of a class?
I am writing an application that applies different analyses to a set of data. The program must be flexible configurable. To not clutter the GUI with too much elements I ended up with the idea to load the needed user interfaces for each specific analysis dynamically into a single sub panel when needed. This works well without any problem.
Due to the fact that all analyses share some common functionality I have decided to use LabVIEW classes for implementation. Each class has one VI representing the user interface to show in the sub panel.
This works also well BUT the sub panel always shows a horizontal and vertical scroll bar I don't want to see!
I have already learned that I need to change the user interface VI to a custom "Window Appearance" and disable the "Show scroll bar" properties. But this seems to work only for "normal" VIs but not for VIs that are part of a class.
Any ideas?
Ingo
(3,468 Views)
Hi Ingo
For your problem there will be a solution, please follow the link below. I hope this will help you to solve the problem.
http://digital.ni.com/public.nsf/allkb/61F9121357C005008625710F000753A2?OpenDocument
Kind regards
(3,436 Views)
Accepted by topic author IngoB
Thanks Pixar, this was the right tip!
Although: there seems to be a difference between "normal" VIs and VIs that are members of a class.
For "normal" VIs it is sufficient to set the property to "Off While Running" and it works as expected.
VIs part of a class need the "Always Off" setting" which is only accessible via right click on the scroll bars but not via the VI's properties box.
Thanks and Regards
Ingo
(3,423 Views)
