How to get recent data on control
Hi All,
I need to create an GUI which has some interactive inputs. I want to keep the data entered by the user as cookies so that when user comes back to same GUI with the key focus on the control, the control displays the recent data and user can select form the display or user can enter a new data in the control.
Can you please suggest me some option that consumes less memory.
Thanks in advance.
Pankaj
Message 1 of 10
(3,856 Views)
It sounds like you want a Ring control.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(3,844 Views)
Hi
Message 3 of 10
(3,832 Views)
No, you can access a ring controls properties and write to Strings[] property in runtime, or Strings and Values[] if you dont want sequential values.
/Y
Qestit Systems
Message 4 of 10
(3,822 Views)
You just have to decide where you write the values. An ini file is often used.
Message 5 of 10
(3,803 Views)
Thanks for reply...
Writitng data in .ini file will work in case of ring or combo control but we can do the same kind of operation with string control or numeric control.
I already use similiar technique in one small application where I am using a combo box control. I want to implement this functionalities on string control or numeric control.
Message 6 of 10
(3,785 Views)
That's definatly a ring control (or enum, but it cant be changed in runtime). 🙂
/Y
Qestit Systems
Message 7 of 10
(3,770 Views)
/Y
Ring controls can be changed in runtime only Enums can't. 🙂
For any control the default value can be set through vi scripting.
Message 8 of 10
(3,766 Views)
P@Anand wrote:
/Y
Wasn't that what i said? 🙂
Qestit Systems
Message 9 of 10
(3,759 Views)
I read that the other way. May be my compiler problem 😛
Message 10 of 10
(3,752 Views)
