How to get full path of caller VI?
Labview 8.x broke my code.  I used to be able to refer to a VI by its name, and now it wants the full path.  Unfortunately, "call chain.vi" only returns the name.  Does anyone know how to refer to the vi (its full path) that calls a particular subvi, from the subvi?  It used to be the second element of the string array from "call chain.vi".
I'm using LV8.6.
Jeremy
(5,680 Views)
Accepted by jeremy_levy
Hi Jeremy,
I'm not sure about 8.6, but in 8.5.1 you can still use a string containing the VI name to open a reference of a VI that is in memory.
You can't use a path constant with just the VI name though.
VI ref by name
Daniel
Message Edited by dan_u on 02-17-2009 08:34 AM
(5,669 Views)
With 8.x you can still refer to a VI by just its name if its already in memory - which a caller obviously should be. Can you post the code that is causing the trouble? Or perhaps explain more completely what you are trying to do and what happens?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,660 Views)
Thanks--I had almost that in my pre-8 code, but there was a path to string conversion that 8+ does not like (and 8- required).  It was very useful to compare your png with my code.
Jeremy
(5,640 Views)
Actually, you have always been able to wire a string to the open function like that.
Mike...
LabVIEW Champion
(5,622 Views)
