How to get for a VI instance its own SubVI Refnum
Oops, looks like someone is still using LV 2011!  Smiley Wink
Seriously I thought I would be able to change the label too, but now it is grayed out in the Properties dialog (in LV2013).  So I tried earlier versions and it looks like that "feature" was added in LV2012.
Message 21 of 23
(1,422 Views)
That's good to know.  I had tested it in LV2012 and it worked.  I didn't think it was something that might have not worked in the past and was only recently added.  The only thing I noticed was that double-clicking the label wouldn't allow you to edit it.  You had to explicitly go to the properties dialog.
Message 22 of 23
(1,418 Views)
Accepted by Manu56
Finally... if your VI is a VI express then you can achieve this... what a mess !
Message 23 of 23
(1,373 Views)
