How to get data from executable
Hello everyone,
I'm a beginner of LabVIEW, and recently have some problem about "get data from .exe". Now I have an .exe of random number generator, and is it possible to get the number by .vi ? (The attachment is  rng.exe). Hope someone can help me, and don't be hesitated to ask more detail.
Thanks a lot
Albert
Message 1 of 8
(5,246 Views)
Hi Albert,
I don't think I will start any EXE from a public forum without being able to see it's code…
You can use several options:
- save data to a file
- publish data over network communication (UDP, TCP, SharedVariables, NetworkStreams, many more…)
- use a screen scraper with image analysis to get the displayed numbers…
Message 2 of 8
(5,237 Views)
@GerdW wrote:
Hi Albert,
Oh, I like the last one! Create a .jpg as output from the program and then read it with OCR! 😄
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(5,230 Views)
Sorry for that, let me update the rng code.
Message 4 of 8
(5,228 Views)
Hi Albert,
use any of the previously mentioned options…
Btw. not everybody here uses 7zip, so you should use plain ZIP when compressing files/folders. For simple (and small) VIs you don't even need to compress them…
Message 5 of 8
(5,225 Views)
Using invoke node allow me to easily read data from this vi (rng.vi). However, when I convert rng.vi to rng.exe, the invoke node seems to be disable...
Message 6 of 8
(5,219 Views)
Accepted by YuChuanHuang
Hi Albert,
Yes.
That's a system protection in most modern OS: you don't want one executable being able to manipulate data in another executable! In a modern multitasking OS each executable uses it's own memory scheme! When you want to communicate between executable you should use network functions…
When you just need a RNG you should implement that function in a DLL. Then call that DLL function using the CLFN from your other executable!
Message 7 of 8
(5,207 Views)
Thanks for your kind reply and providing me some way to study.
Message 8 of 8
(5,198 Views)
