How to get a steady input signal
@ceilingwalker wrote:
@Jimmy.chretien wrote:
What you want to achieve is moving average, have a look at the VI here and adapt it for you.
http://www.ni.com/example/25082/en/
I have tried this a number of times but the only thing I can find on averaging requires a waveform. All I have is a table of data.
The example VI (on the right of that page) doesn't require a waveform. It takes in a single point and keeps the previous points in memory and averages them together and each point comes through. You would implement this to go with your acquisition.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 11 of 11
(823 Views)
