How to get SCXI card type from a channel?
I'm trying to create a generic VI that can handle different types of inputs.  Right now, I have analog inputs going to either a PXI-6224 (directly), an SCXI-1104 (controlled by a different 6224), and an SCXI 1530.  My VI uses a configuration file where the user specifies which channel to use.  Since it's possible that the user gave a name to the device in MAX, I can't rely on the device name to determine whether I should set up the bridge circuit attributes for the 1530.  Is there a way I can pass in the channel ID like "Dev1/ai5" and get back "SCXI-1530"?
Keith.
(2,433 Views)
Hi
    i am not sure i have got your point. But i guess this Vi may help you. Let me known if so.
(2,426 Views)
