How to generate response file for NI 9229 device
My target is to establish a response file for the 9229 device. Response parameters typically consist of a sensitivity or "gain", measured at some specified frequency, and a set of poles and zeroes for the transfer function that expresses the frequency response of the NI-9229.
The 9229 is a 24-bit ADC, and note that there is only one input range, +/- 60 V, on the 9229.  So, per that equation, (120 V)/([2^24] - 1) = ~7.2 uV we can calculate the sensitivity. However, for poles and zeros, I can't find any information in the manual about them. Kindly, how to solve this problem.
(1,614 Views)
Hi Emad,
Well, in the datasheet for the NI9229 you will find explicit information on passband and stopband characteristics!
There's a whole chapter on filtering behaviour and a lot of numbers in the specs section…
Do you need more information?
(1,598 Views)
Thanks, Mr. GerdW for your cooperation. Yes, I need more information if you have. Or how to use these information to calculate poles and zeroes (transfer function) for NI-9229 device?
(1,589 Views)
Hi Emad,
It's been a while since I had to calculate transfer functions using poles/zeros - maybe 20 years ago.
So I guess you have some books explaining those calculations and you got trained to apply them!
The datasheet mentions
  • a passband frequency of 0.453*fs with a flatness of <= 0.1dB
  • a stopband frequency of 0.547*fs with rejection of >=100dB
There surely are formulas to convert those numbers into poles/zeros in the imaginary plane…
(1,571 Views)
