How to generate a string with a known length with a particular character.
@aeastet wrote:
I think he was giving you a hard time because you posted it using LabVIEW 2021. Not that what you did was not available before that. 😁
No, I assumed that it must be a new feature. Whenever I try to do a concatenating tunnel with a simple string, the wire breaks. Obviously, I am doing something wrong....
(I use the concatenating tunnels for arrays all the time and am aware of that.)
Message 11 of 18
(1,414 Views)
I could never get the hang of the concatenating tunnel for strings either. Seems to be hit-n-miss for me. This particular case does not work in LV2020 for me either.
Message 12 of 18
(1,399 Views)
For me it works with LV2021, but not LV2020 or earlier.  Interestingly it's not mentioned in the What's New documentation for LV2021.
Message 13 of 18
(1,393 Views)
You are right this does not work in LabVIEW 2020 sp1.
Interesting as I just skimmed the LabVIEW 2021 release notes, bugs fixes, and new features, but I see no reference to this being fixed or feature changed.
Some developer must have just snuck this in?
=== Engineer Ambiguously ===
Message 14 of 18
(1,391 Views)
Accepted by topic author msabah38
While we are finding (silly) alternatives, here's another one: 😄
(seems to operate mostly in-place)
Message 15 of 18
(1,377 Views)
 ... and its a great new feature. Very intuitive. I cannot count how many times I tried to concatenate strings using a concatenating tunnel in the past, then just getting slapped with a broken wire instead. 😄
Message 16 of 18
(1,376 Views)
@kartiknattar wrote:
Are you trying to replace the strings or you want to display the string as password??
If you want to display the string (control/indicator) as password you can try below method by just right click.
How to do it programmitically, also instead of * character if I want to use # character how to do that.
Message 17 of 18
(1,342 Views)
You can make your own workaround. ("Key down?" filtering event, store actually entered key and display #, etc.)
(Not sure why you would want to have nonstandard behavior. Just to confuse the user?)
Message 18 of 18
(1,337 Views)
