07-11-2012 09:54 PM
My Fluke 5500A encountered an error code 1004, does anybody help me the solve the problem.
Thx.
07-13-2012 12:57 PM
Hello ,
Thank you for using National Instruments forums.
You are not being very specific about when and where are you getting this error. Anyway maybe this will help.
12-18-2013 03:27 PM
Hi, I have a Fluke 5500A but I can´t communicate with LabVIEW, also, with Hyperterminal is working, could you help me please?because in Initialize.VI I have an error whose code is -1074001421 or for its hexadecimal representation (0xBFFC09F3).
Thank you.
12-19-2013 08:43 AM
When does this occur? Are you running the initialize function before anything else? This will call the Default Instrument Setup function which sets the user data for the actual instrument being used. As the error popup says, the BFFC09F3 error means "Required Instrument model is not available."
12-19-2013 09:56 AM
yes, I used initialize.vi first, I solved the problem, but sometimes that error appears again. Do you know the reason?
12-19-2013 09:59 AM
I don't know the reason. It would help if you attached your code.
