How to fix the Labview Decorations with Tabs
I am using a decoration box in my front panel, I want to fix that box with tab, so that user can't move it or drag it. Is there a way to do that?
Faizan Habib
Message 1 of 8
(2,817 Views)
Hi Faizan,
I don't understand your problem: why/how should a user be able to "move or drag" a decoration on your front panel of your executable???
Message 2 of 8
(2,813 Views)
So, you can see in below screen shots, the background box is moveable, I want to fix it so that user can't even select it when put cursor on the box, user should only access the controls.
Message 3 of 8
(2,793 Views)
Hi Faizan,
You can group front panel elements…
Still the question is: why do your users have access to VI front panels in edit mode?
Message 4 of 8
(2,788 Views)
Accepted by Faizan_habib
You can lock any front panel object, even decorations.
Message 5 of 8
(2,770 Views)
You can "lock" everything on the panel like Basjong53 has shown, but your end user can simply "unlock" them.
GerdW has an extremely valid question that I will rephrase.
Why are your end users running programs from the LabVIEW development environment?
This issue will not exist if you are compiling your LabVIEW program into a Windows executable and distributing that to your end user.
BTW: You are free to distribute and even charge money for executables, no further licencing is required.
=== Engineer Ambiguously ===
Message 6 of 8
(2,757 Views)
So, right now the project is in debugging stage, here the user means me and my colleagues.
Message 7 of 8
(2,748 Views)
Actually you can lock things individually here is an example
Tim
GHSP
Message 8 of 8
(2,717 Views)
