How to find largest number from text file
I am using the "Read from text file" block to read the data from my .txt file into labview.  It is now in string format.  I have many numbers in the file.
For example:
0.45
0.35
0.12
1.354
1.56
2.89
5.89
0.56
That is what a text file might look like.  I want to find which of these numbers is largest, and do calculations with that number.  I am having trouble with strings/number formats/arrays, etc.  Thanks
(4,180 Views)
Accepted by Benjammin0789
Try reading the file with the Read From Spreadsheet File.vi with Transpose set True. Then use Array Max & Min to get the largest number in the array.
Lynn
(4,175 Views)
Yes, that works.  I guess I couldn't get past the thought that my text file is not a spreadsheet, and so I assumed that read from spreadsheet vi would not work.  Thank you.
(4,171 Views)
The spreadsheet functions and VIs typically work on strings representing numbers separated by delimiters.  This is a typical way to save a "spreadsheet" (of numbers) to a text file, for example .csv files.  These are quite versatile and powerful functions.  Spend a bit of time becoming familiar with them because you may find yourself using them a lot.
Lynn
(4,167 Views)
Right on.  Now, do you have any idea how to delete text files from an sd card?  After I grab the data, I want to wipe the sd card clean from labview with a button and be on my way.
(4,162 Views)
File I/O palette >>  Advanced File functions >>  Delete File.
The SD card should have a drive letter assigned, so you just use that in the path you send to the delete file function.
(4,157 Views)
Yes, thanks
(4,152 Views)
