How to find a modem's com port number programmably if I know the name of the modem interface?
Accepted by 2014spring
Here it is in LV 2014
Message 11 of 15
(1,772 Views)
Hi Paul,
Wow, your "old" stuff really shined a light on me. You got a lot of stuff there and I think I'm overwhelmed by the power of your code! I alreay saw my modem showing up there with the name and com port number all together...ha...I'll try to digest a little better and pull out the part that I really needed. Did you write all those get managementbase subvis, Paul? Anyway, thanks a bunch for sharing your old stuff! It's very helpful!
Best,
Spring
Message 12 of 15
(1,745 Views)
@2014spring wrote:
Hi Paul,
Best,
Spring
I did write the management VIs, but I figured it out by looking at other peoples' code (don't remember who or when).
Message 13 of 15
(1,086 Views)
Hi Paul, I'm facing a new problem now. I have two devices that all show as "USB Serial Port" in Device Manager. The only difference that I found is their hardware ids in the properties. I tried "Get_USB_List_and_Props PLUS.vi" with filter "Select From Win32-USBDevice". It returns devices with Hardware ids but no COM port numbers. How do I get both Hardware id and COM port number in LabVIEW?
Message 14 of 15
(1,084 Views)
Sorry, I don't know.  I've had a similar problem and tried many times (always failing) to find the relationship between a COM port number and an identifier (such as a USB path) to a particular piece of hardware.
Message 15 of 15
(993 Views)
