How to filter noise images?
Thank you for your clarification!
I'm still confused regarding the sine wave kernel size equal to 1 x 100 (1 row and 100 columns)! Could you please send me any tutorial or information on internet about the difference between the square kernels and line kernels, exact name of the used sine wave kernel and the advantages in comparison with the gaussian filters.
After changing the values of the threshold, 2' smooth and HkernelWidth edit labels I noticed that cells are swelling along the Y axis (more spherical). How to correct that?
Message 31 of 41
(1,544 Views)
I guess I don't see what you are seeing.... sizes look pretty similar.
All you need to understand is what convolution does, then play with the parameters. Any smoothing and thresholding will have an effect on the actual outlines of objects. You can think of your cells as little bumps in 3D (brightness is Z) and a low threshold will give a larger outline than a threshold that just clips the very tip. Adding broadening will again change things and the outlines will become smoother.
Message 32 of 41
(1,525 Views)
As I said, you background is blurry in x and sharp in y. We can blur significantly in x and it does not really change, but the cells get wiped out. If we would also blur in the y direction, the background structure is not retained.
Here is a simple comparison showing the picture after the first convolution. only the Hkernel does what we want.
If you would use a symmetric kernel, you get something in-between... (not shown)
Message 33 of 41
(1,518 Views)
Thank you for your assistance!
On the image there are small extension along Y axis. I marked with arrows the size along Y axis, thus showing my expectations:
I see that along X axis it seems well filtered but along Y axis there is a small extension of the cell. May be the cell has to be till the end of the white contour on the top of the cell (high intensity). May be I can mask it additionally.
Message 34 of 41
(1,501 Views)
In fact with the sine wave kernel 1 x 100 you create a background blurring in x. If I use the same sine wave kernel but 100 x 1 the background is blurring along Y and the background structure will change.
With the sine wave kernel you create a blurry image of the background. Тhe cells blur until they blend into the background, right?
From the original image you subtract the background image and you can see only the cells, right?
I don't know exactly the part of the code, marked in red rectangles:
Could you please explain a little bit more? Thank you in advance!
Message 35 of 41
(1,496 Views)
You cannot simultaneously filter and threshold while retaining all minute details. You can clearly see that all your cells have a slight shadow above that gets picked up. You might be able to eliminate it at the cost of problem elsewhere.
You have not said what result you really need. for example for cell counting, the exact shape is not important.
If all cells are supposed to look identical, maybe you can take the average of a few dozen aligned cells to get the prototype (grey ring, darker center, bright halo above, etc.) and use that for complicated feature detection, e.g. using AI.
Message 36 of 41
(1,491 Views)
TOP: this part adjust the image indicator to the size of the image (ensuring that we see all data). It is not needed and just cosmetic.
MIDDLE: Any convolution gives you edge effects because border pixels are surrounded by fewer other pixels. I pad the image based on the kernel size, then trim it back to the original size later.
Why not do some experiment and e.g. just bypass parts of the code that are unclear and see how the result gets worse. 😄
BOTTOM: Creating a symmetric 2D kernel is most easily done by creating a 1D kernel followed by the outer product.
Message 37 of 41
(1,487 Views)
Message 38 of 41
(1,477 Views)
Hello!
Thank you for your help! Could you please assist me please how to find the contour of the cells thus measuring the diameter of the cells along X and Y axes? Now the cells are rounded a little bit more. I can correct the diameter of the cells on top because I realised that the contour of the cells on top has the highest intensity.
Message 39 of 41
(1,417 Views)
@tiho_bg wrote:
Hello!
From that point, it will be hundreds of times simpler to use the NI Vision Development Toolkit rather than developing everything from scratch in LabVIEW — or alternatively, using OpenCV or other image processing library (directly or via Python scripts).
Message 40 of 41
(1,398 Views)
