How to extract elements with a fixed interval from a 1D array
Accepted by topic author HerbMa
Cory K wrote:
What would you like to use to determine the spacing?
You can make it variable using a control, or some other value from your block diagram.
See the attached example.
Hello C.Clad
I like your Vi but from 8.2 Labview actually has this function.
Decimate (single shot) VI
Owning Palette: Signal Operation VIs
Installed With: Full Development System
Decimates the input sequence X by the decimating factor and the averaging Boolean control
And the to be honest I discovered my self by an accident in Labview 8.6. So yes I did also sleep somewhat in class. The nice thing about this function is that it let choose if you want to just pick out samples or use the average sum between each "down sample" interval
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 20
(2,975 Views)
That is what I am looking for. Thanks for everyone's help!
Message 12 of 20
(2,960 Views)
Coq Rouge wrote:
Hello C.Clad
Did you mistakenly call me 'Clad' or was that a running joke from here? Smiley Very Happy
Cory K
Message 13 of 20
(2,945 Views)
I am quite disappointed C. You should know now that I am always 100 serious in this forum. The Labview forum is way to important for pranks and tricks........Smiley Indifferent
Smiley Very Happy
Message 14 of 20
(2,924 Views)
OK, I know this is late but I just stumbled on this thread as I was looking for something similar.  Here is another stab at decimation (homemade).  This VI runs about 4-5x faster than the VI pointed out by Coq.  It doesn't have the ability to select the initial index at which to start decimating, nor does it have bounds checking, but this should be fairly straightforward to implement.  It's similar to Cory's solution but uses the array indexing on the bounds of a for loop to improve performance.
Just thought someone might be interested.
Peace, Matt
Message 15 of 20
(2,798 Views)
Is there a performance difference to my second solution? I would expect both solutions to have similar performance. However your solution might be faster, because of some implicit coding which is faster than my explicit suggestion.
Message 16 of 20
(2,755 Views)
Maybe this implementation (if you don't mind the coercition dots) which takes into account the starting index?
Message 17 of 20
(2,728 Views)
Your image is pointing to your hard drive.
The easiest thing to use is the 'Upload or insert an image on the toolbar above.
Message 18 of 20
(2,726 Views)
Ok thanks...I've done a copy&paste.  The image was showing on my side.  Here's the "real" image:
Message 19 of 20
(2,717 Views)
Jorn,
The indexing on the bounds of the array is about as fast as the example you provided.  Interestingly enough, adding the routine as a subvi adds considerable overhead.
Peace, Matt
Message 20 of 20
(2,707 Views)
