Text ring initial selection
How do I programmatically change the initial selection of a text ring (the one with the check mark)?
Which property would I need to set?
(3,780 Views)
I think I found the answer, by setting the Value property.
(3,772 Views)
Or just use a local variable. That's a faster way.
(3,766 Views)
How would you use a local variable?
(3,763 Views)
Same way you would use a property node. Wire a value to it. Just right click and select 'Create Constant'.
(3,752 Views)
