How to extract 1 Darray and put them into new array
oh..so he was needed the index 30.
Message 21 of 28
(1,958 Views)
Hay bijay,
I have done it already and it's also similar as yours .
thanks for your help 🙂
regards
Message 22 of 28
(1,957 Views)
HI bijay,
What is snippet you mentioned above? can put .png file to labview?
Message 23 of 28
(1,956 Views)
Accepted by pyae
Just save the image, drag and drop on to LV Block diagram.
You will get direct code.
Try it.
Bijay
Message 24 of 28
(1,949 Views)
Slightly different approach below:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 25 of 28
(1,942 Views)
Hello ManLD,
Sorry that i mentioned wrongly and make you busy . Now my problem solved  and thanks alot for your help .
regards
pyae
Message 26 of 28
(1,937 Views)
no problem ..
always ahead to answer your queries..
Message 27 of 28
(1,925 Views)
Another solution. You're basically looking for a Decimate Array, but as it felt somewhat difficult to get exactly 1-to-30 i want for 1-to-6 and 1-to-5 for a total of 1-to-30. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 28 of 28
(1,906 Views)
