‎08-25-2009 02:14 PM
‎08-25-2009 02:19 PM
You use the DisabledItems[] property. The input is an array and you pass it the index of the elements you want disabled.
‎08-25-2009 02:19 PM - edited ‎08-25-2009 02:20 PM
maybe you can use the disabled Items[] property
dennis beat me to it.....
‎08-25-2009 02:47 PM
how to enable for disabling i am passing array with indexes i want to disable for enable what should i do.
‎08-25-2009 02:53 PM
‎08-25-2009 02:57 PM
‎08-25-2009 03:32 PM
‎01-31-2017 04:27 AM - edited ‎01-31-2017 04:28 AM
Dennis, thanks for your answer.
‎06-26-2025 09:13 PM
Suppose that enum control is actually inside in an array....
Could I, for example, disable the 2nd enum element of the 1st array elements, the 5th enum element of the 2nd array element, etc.?
My gut feeling is no, because there's no way to access the individual array elements with property nodes.... Or is there?
‎06-27-2025 01:07 AM - edited ‎06-27-2025 01:08 AM
No, there isn't. All elements of an array share all their properties. Array elements can only differ in value.
