How to download waveform over RS-232 to HP 33120A FG?
Hello all, I recently aquirred a HP / Agilent / Keysight 33120a function generator. I have gotten the SCPI command interface working and can execute commands with a null modem cable and RS-232 to usb cable. I was wondering however about how to download waveforms over the selected interface as the Agilent IntuiLink software doesn't recognise the device and can't connect. Driver issue or software issue?
(1,805 Views)
Based on the quick guide, you use the DATA VOLATILE command to load up the data.
(1,793 Views)
Hi T,
What does the Agilent support say about that problem?
Read the programming manual for your device to learn about the SCPI commands you need to use…
Are you talking about LabVIEW problems or about that "Agilent IntuiLink" software?
Why doesn't the IntuiLink software recognize the device? Can it use the (virtual) COM port at all?
Which driver are you talking about?
(1,790 Views)
But how does this command work? The manual says I need to send an array of bytes?
(1,778 Views)
Hi T,
The manual says:
It does not mention any "bytes", but float values or "binary" data of upto 8K (8192) samples!
And it explicitely explains the needed commands in the following pages…
(1,772 Views)
