How to do this nested loop inside labview
i2d=[]
img=[]
for j in range(0,129600,360):
    i2d=[]
    for i in range(j,360+j):
      i2d.append(data[0][i])
    img.append(i2d)
(3,212 Views)
You can easily put a loop inside of a loop.  You could probably do all of the appending of arrays by simply using autoindexing terminals.
(3,207 Views)
there is a 1Darray of length 129600 and I want to create a 2D array of 360x360 out of it
I'm new to Labview and confused to do it
i2d=[]
img=[]
    i2d=[]
      i2d.append(data[i])
    img.append(i2d)
(3,198 Views)
I tried but was not able to do so can you provide screenshots
I'm confused how to append to array that RED BOX
means I am unable to change default array ([0]) with appended array
I'm new to this
(3,201 Views)
Accepted by gptshubham595
Something like this?
(3,191 Views)
Just wire from one tunnel to the next.  It will go from a 1D array to a 2D array.
(3,177 Views)
