How to do arbitration in LabVIEW FPGA
Hi vicky,
how we decide that which one is receiving request first out of five devices.
You read your 6 digital inputs as fast as the FPGA or the module allows, I often also read the full port (group of 8, 16 or 32 bits). Whenever one of those bits is toggled (hint: XOR function!) you know there is a "request" and you can handle this request by setting some other digital outputs…
Can we have to use case statements for all this in FPGA VI
Yes, sure.
or some other way ??
You can use many other functions and structures in a FPGA VI, even FIFOs (aka queues)…
Message 11 of 21
(2,358 Views)
yes by using XOR gate we will find there is request but how we determine which request we receive first.
Message 12 of 21
(2,350 Views)
Hi vicky,
by default the FPGA executes loops at 40MHz - or 25ns between iterations. Do you really expect more than one request in this short interval?
I assume there will be only one request per 25ns interval so you know which request occured in which iteration of your receiver loop…
Message 13 of 21
(2,343 Views)
Set a flag, enqueuer an element, execute a case, output a value, store the timestamp, trigger an SRQ... Thousand ways to do it.
Recommending one of them is not easy, as what makes the right choice it's highly circumstantial. E.g. it depends... On an FPGA everything usually needs to fit like a glove. Each choice made needs to fit other parts.
I am pretty sure arbitration is not required to solve the problem.
Message 14 of 21
(2,340 Views)
yes you are right. but then also how we determine which device request we receive first.
Can you please give me a small example by taking two or three inputs and then how we determine which one we receive first?
Message 15 of 21
(2,337 Views)
Can you please give some example by taking two or three input and then how we determine which one we receive first ?
like by taking case statement
Message 16 of 21
(2,341 Views)
Hi vicky,
using standard LabVIEW it looks like this:
In the FPGA you may do the ArraySearch "manually" using your own routine…
That "first" request is the one, where the boolean value changed in an earlier iteration then the "second" one…
You need to take into account the loop iterations between the comparison of your digital inputs!
Message 17 of 21
(2,337 Views)
Or detect going up:
Message 18 of 21
(2,332 Views)
can you please tell where i can find the highlighted part in the picture attached
Message 19 of 21
(2,323 Views)
Hi vicky,
both our suggestions are actually snippets! You can download those images and drag&drop them into the block diagram of a VI to get their contents…
You are looking for a feedback node. You really should take the beginner courses!
Message 20 of 21
(2,307 Views)
