How to display the serial waveform on Labview
I'm a newbie in Labview Programming. Is it possible to display the serial waveform on the display using Labview?
From
Don
Message 1 of 13
(5,275 Views)
Hi
I don't know if I've understood the question.
With the waveform chart you can visualize a point to point graph.
Otherwise, you can buid an array inside a loop and then representate it in a waveform graph, in order to have al the samples.
I hope to be useful
Miquel
Message 2 of 13
(5,274 Views)
hi Miquel G.
how am i able to look at the RS232 signal. I understand that the signal consist of start and stop bits, and the info. Is it possible to visualize the voltage levels?
From
Don
Message 3 of 13
(5,261 Views)
If I've understood, you want to measure the voltage of an RS-232 signal. It's not possible directly. The reception of the signal is made by the UART of your computer and then, what LabVIEW does is to access to its register to obtain the received data, but only at digital level.
If you want to measure these signal levels, you've to use any mean of adquisition signal system
Regards
Message 4 of 13
(5,252 Views)
hi,
thanks alot
From
Don
Message 5 of 13
(5,244 Views)
Are you trying to test a UART to see if it meets specs? That would seem to me to be the only reason you need to measure voltage levels. If you're trying to do something else, could explain a little more?
Message 6 of 13
(5,240 Views)
From theory I've understand that RS232 signals take a certain kind of waveform. I'm trying to see if the RS232 which I'm passing into my serial port could be visualize using Labview.
thanks
Message 7 of 13
(5,226 Views)
RS232 transmits binary. If you transmit the character A, that gets converted to hex 41 or 01000001 (assuming 8 data bits). There is also start, stop, parity bits. The logic levels for RS232 can between +3 to +12 volts or -3 to -12 volts. When you use LabVIEW to read a serial port, the UART in the pc will convert that digital data back into the character A and that's what LabVIEW or any other communications program like Hyperterminal will read. What exactly do you have hooked up to the serial port of the pc? Is it some kind of instrument or what? If it's an instrument sending data, then how the data is interpreted is dependent on the instrument. It might send back a reading as text. A 1 volt measurment might be transmitted as the ASCII characters "1" and "v". Other instruments might encode the data differently. Measurements made over a serial port can be easily visualized. Plain text received over a serial port is usually displayed as text.
Message 8 of 13
(5,222 Views)
I've hook up the serial port with a GPS receiver.
From
Don
Message 9 of 13
(5,210 Views)
Frankly, that's a completely different problem than what it seemed you were first asking about. While I have a new GPS hand-held, I haven't yet hooked it up to a pc, but, the good news is that there have been numerous threads on that subject. A GPS will transmit data in something called NEMA format. Do a search of the forums (you may have to go back further than the default of 90 day) for NEMA and/or GPS. You should find some helpful information and probably an example VI or two.
Message 10 of 13
(5,200 Views)
