How to display current time when the inputs are added together and display intervals every sec?
Hi, I added the values together but the time in the graph is not showing the present time.
The one that is not displaying the current time is the voltage graph.
On the x-axis of the voltage graph i want it to display every second interval.
Thanks.
(2,749 Views)
Upload the VI (2011)
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,739 Views)
Since you are not setting the offset and multiplier in any place that I can see, there is no reason for the chart to display any correct time on the x axis. The values have to come from days you provide - they don't just come out of thin air.
Your case statements are perfect examples of rube goldberg code, 🙂
(2,717 Views)
You also shouldn't be using the local variables.  Instead, actually add up the signals from the wires.  What you have there is a race condition since you can be reading from the local variables before the terminal is written to.
(2,686 Views)
