How to develop labview script for CAN using CRIO 9045 and NI CAN 9853.
Hi rishijha,
I never had to deal with those bits.
I just supply ArbID and payload and the NI9853 handles all the messaging on its own…
Message 11 of 17
(1,316 Views)
how much arbitration bit u used for ur application??29 bit  or 32bit.
Message 12 of 17
(1,312 Views)
Hi rishijha,
CAN ArbIDs are either 11 or 29 bits.
I use a 32bit datatype to store those values in my software…
Message 13 of 17
(1,310 Views)
32bit datatype
so when we will supply 11bit or 29bit arbitration id from s/w internally NI 9853 will arrange these bit according to attached screenshot frame format??
Message 14 of 17
(1,303 Views)
Hi rishijha,
yes, the NI9853 handles that on its own…
Message 15 of 17
(1,298 Views)
AFAIK the NI9853 CAN module has to be programmed in the FPGA of your cRIO
can u explain more about AFAIK.where i will get this information.
Message 16 of 17
(1,292 Views)
Hi rishijha,
One way is to call your local NI support.
Another way is to discuss such questions with your local NI sales rep.
You can also examine the example VIs in the example finder…
You might also read the whitepaper offered in the NI9853 specs!
Message 17 of 17
(1,289 Views)
