How to develop labview script for CAN using CRIO 9045 and NI CAN 9853.
i am using can 9853 with CRIO 9045.My can device is connected with external device(testing device).i have to send 17bytes of data from can 9853 to external device.but can standard support only 8bytes of data.so i have divided 17 bytes into 8+8+1.so now i have to send these data bytes with standard can format within 200ms(specified) to external device.how to write the code in labview.which type of programming mode or API i can use.i attached the screenshot of can format i am using.please share the best way to develop labview programming.
Message 1 of 17
(4,850 Views)
Hi rishijha,
AFAIK the NI9853 CAN module has to be programmed in the FPGA of your cRIO: this is the API you get!
The manual of your "external device" should tell you, which CAN messages you have to send…
Message 2 of 17
(4,834 Views)
Accepted by topic author Risuraj
Hi rishijha,
this is how it may look like in the FPGA VI:
Sending and receiving messages on CAN0 port of one of the two NI9853 modules I use in my cRIO 9066…
Message 3 of 17
(4,822 Views)
can u share your complete code here??
Message 4 of 17
(4,816 Views)
Hi rishijha,
no, I cannot.
But you find example VIs/projects for each cRIO module in the example finder!
Message 5 of 17
(4,814 Views)
i gone through example code.they used fpga I/O Node to transmit data.where we can send 6*U32 byte data.but the frame i am sending that is different from example frame.
what i am sending
SOF(1bit)+Arbitration field(29bits)+Control field(4bits)+Data field(8 Byte)+CRC(15bit)+ACK(2bits)+EOF(7bits)
Message 6 of 17
(4,808 Views)
Hi rishijha,
the CAN module (and its hardware driver) will handle the low-leven part of creating the full CAN message consisting of SOF…EOF. You only need to supply the ArbID and the data bytes!
That will be 3 CAN messages, each one containing 2 U32 values…
Message 7 of 17
(4,797 Views)
where i will get these details.so remote frame is same what i mentioned previously.
Message 8 of 17
(4,761 Views)
Hi rishijha,
You get all the details in the manual of your external device…
Message 9 of 17
(4,742 Views)
How to set the SRR ,IDE and RTR bit of Arbitraion field.i have only 29 bit(identifer) information of external device.will these three bit is controlled by the h/w(NI 9853) or we have to do by programming.
Message 10 of 17
(4,729 Views)
